주요 콘텐츠로 건너뛰기
Motorola E815 Keypad Replacement
필요한 것
  1. Motorola E815 Keypad Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Keypad Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Keypad Replacement: 3 단계, 이미지 1/2 Motorola E815 Keypad Replacement: 3 단계, 이미지 2/2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Keypad Replacement, Disassembling Motorola E815 Antenna: 4 단계, 이미지 1/1
    • Locate the antenna port on the top of the phone.
    Removing Antenna Only
    Zoie E - 답글
  5. Motorola E815 Keypad Replacement: 5 단계, 이미지 1/2 Motorola E815 Keypad Replacement: 5 단계, 이미지 2/2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Keypad Replacement, Keypad: 6 단계, 이미지 1/1
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Motorola E815 Keypad Replacement: 7 단계, 이미지 1/3 Motorola E815 Keypad Replacement: 7 단계, 이미지 2/3 Motorola E815 Keypad Replacement: 7 단계, 이미지 3/3
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Motorola E815 Keypad Replacement: 8 단계, 이미지 1/3 Motorola E815 Keypad Replacement: 8 단계, 이미지 2/3 Motorola E815 Keypad Replacement: 8 단계, 이미지 3/3
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Motorola E815 Keypad Replacement: 9 단계, 이미지 1/2 Motorola E815 Keypad Replacement: 9 단계, 이미지 2/2
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Motorola E815 Keypad Replacement: 10 단계, 이미지 1/2 Motorola E815 Keypad Replacement: 10 단계, 이미지 2/2
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Motorola E815 Keypad Replacement: 11 단계, 이미지 1/3 Motorola E815 Keypad Replacement: 11 단계, 이미지 2/3 Motorola E815 Keypad Replacement: 11 단계, 이미지 3/3
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zoie E
회원 가입일: 01/12/11
603 평판
안내서 5개 작성하였습니다
Cal Poly, Team 14-8, Forte Winter 2011 Cal Poly, Team 14-8, Forte Winter 2011 회원
CPSU-FORTE-W11S14G8
5 회원들
안내서 5개 작성하였습니다
댓글 2개
We should have a motherboard replacement.
Santi12008 - 답글
We need to fullify more this content.
Santi12008 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,084
