이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the battery removal slot.
Use your finger to pull the battery out from the top.
Remove the battery.
Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
Pull the apparatus up and out of the phone.
Locate the two screws on the backside of the phone.
Unscrew the two screws using a T6 Screwdriver.
Gently pull the top section of the phone upwards until you feel some resistance.
Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
Using tweezers, gently pry the connector from the circuit board.
Carefully detach the two sections of the phone.
Using the blue pry tool, carefully pull the keypad frame away from the keypad.
Gently remove the keypad frame from the keypad.
Lift the silicone keypad cover off.
Rotate the phone around so that you are looking at the battery cavity.
Locate the screws on the bottom base of the phone.
Rotate the phone back to the front side.
Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
Separate the keypad from the circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
We should have a motherboard replacement.
Santi12008 - 답글
We need to fullify more this content.
Santi12008 - 답글
