주요 콘텐츠로 건너뛰기
Motorola Edge Plus 2020 Back Cover Replacement
필요한 것
  1. Motorola Edge Plus 2020 Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Motorola Edge Plus 2020 Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Motorola Edge Plus 2020 Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Use an iOpener or hair dryer to heat the perimeter of the back cover to loosen the adhesive beneath.
    • Insert the tip of an opening pick 2-3 mm into the seam between the back cover and chassis.
    • Slide the pick around the entire perimeter of the case to sever the adhesive, inserting additional opening picks periodically to prevent the back cover from resealing.
    • If the adhesive hardens as it cools, apply additional heat as needed.
    • Remove the back cover.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
회원 가입일: 03/29/22
17,290 평판
안내서 74개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 118
