주요 콘텐츠로 건너뛰기
Motorola Krzr K1m Battery Replacement
  1. Motorola Krzr K1m Battery Replacement, Battery: 1 단계, 이미지 1/2 Motorola Krzr K1m Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Battery Replacement: 2 단계, 이미지 1/1
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Battery Replacement: 3 단계, 이미지 1/1
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
결론
Jennifer Hudiono
회원 가입일: 01/13/10
42 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010 회원
CPSU-FORTE-W10S11G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 14
전체 시간: 5,553
