소개
To complete this guide you will need to remove the bottom case of the lapdock and remove the battery. To do this you will remove the keyboard and the screws underneath it. After completing the following steps you will need to remove the four screws underneath of the lapdock and then continue to remove the battery.
필요한 것
To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
다른 4명이 해당 안내서를 완성하였습니다.
