주요 콘텐츠로 건너뛰기
Motorola Lapdock 100 Speakers Replacement
필요한 것
  1. Motorola Lapdock 100 Speakers Replacement, Lower Case: 1 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement, Lower Case: 1 단계, 이미지 2/2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Speakers Replacement: 2 단계, 이미지 1/1
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Speakers Replacement: 3 단계, 이미지 1/1
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Speakers Replacement: 4 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement: 4 단계, 이미지 2/2
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Speakers Replacement: 5 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement: 5 단계, 이미지 2/2
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Speakers Replacement: 6 단계, 이미지 1/3 Motorola Lapdock 100 Speakers Replacement: 6 단계, 이미지 2/3 Motorola Lapdock 100 Speakers Replacement: 6 단계, 이미지 3/3
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Speakers Replacement: 7 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement: 7 단계, 이미지 2/2
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
  8. Motorola Lapdock 100 Speakers Replacement, Speakers: 8 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement, Speakers: 8 단계, 이미지 2/2
    • Remove the two 2mm long phillips head screws from each speaker.
  9. Motorola Lapdock 100 Speakers Replacement: 9 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement: 9 단계, 이미지 2/2
    • Insert wisdom here.
  10. Motorola Lapdock 100 Speakers Replacement: 10 단계, 이미지 1/1
    • Unplug speakers from master chip.
  11. Motorola Lapdock 100 Speakers Replacement: 11 단계, 이미지 1/2 Motorola Lapdock 100 Speakers Replacement: 11 단계, 이미지 2/2
    • Unhook each speaker wire from the tabs that are holding them in place.
  12. Motorola Lapdock 100 Speakers Replacement: 12 단계, 이미지 1/1
  13. Motorola Lapdock 100 Speakers Replacement: 13 단계, 이미지 1/1
    • Gently unplug the speaker connection from the motherboard.
결론
Anthony Aiumu
회원 가입일: 01/12/16
770 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 203
