주요 콘텐츠로 건너뛰기
Motorola MBP667CONNECT Circuit Board Replacement
필요한 것
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 1개 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 2개 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: 1 단계, 이미지 3개 중 3개
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
  2. Motorola MBP667CONNECT Circuit Board Replacement: 2 단계, 이미지 3개 중 1개 Motorola MBP667CONNECT Circuit Board Replacement: 2 단계, 이미지 3개 중 2개 Motorola MBP667CONNECT Circuit Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
  3. Motorola MBP667CONNECT Circuit Board Replacement: 3 단계, 이미지 3개 중 1개 Motorola MBP667CONNECT Circuit Board Replacement: 3 단계, 이미지 3개 중 2개 Motorola MBP667CONNECT Circuit Board Replacement: 3 단계, 이미지 3개 중 3개
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
  4. Motorola MBP667CONNECT Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Motorola MBP667CONNECT Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
결론
작성자
3다른 기여자 명과 함께
Jordan Webb
회원 가입일: 01/16/19
112 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 513
