주요 콘텐츠로 건너뛰기
Motorola MC5590 Charging Port Replacement
필요한 것
  1. Motorola MC5590 Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Push in the battery release button.
  2. Motorola MC5590 Charging Port Replacement: 2 단계, 이미지 1/1
    • Pull out battery.
  3. Motorola MC5590 Charging Port Replacement, Keyboard: 3 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement, Keyboard: 3 단계, 이미지 2/2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Charging Port Replacement: 4 단계, 이미지 1/3 Motorola MC5590 Charging Port Replacement: 4 단계, 이미지 2/3 Motorola MC5590 Charging Port Replacement: 4 단계, 이미지 3/3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Charging Port Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Charging Port Replacement: 6 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 6 단계, 이미지 2/2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Charging Port Replacement: 7 단계, 이미지 1/1
    • Remove the keyboard cover.
  8. Motorola MC5590 Charging Port Replacement: 8 단계, 이미지 1/3 Motorola MC5590 Charging Port Replacement: 8 단계, 이미지 2/3 Motorola MC5590 Charging Port Replacement: 8 단계, 이미지 3/3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Charging Port Replacement: 9 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 9 단계, 이미지 2/2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Charging Port Replacement, Speaker: 10 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement, Speaker: 10 단계, 이미지 2/2
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Charging Port Replacement: 11 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 11 단계, 이미지 2/2
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Charging Port Replacement: 12 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 12 단계, 이미지 2/2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Charging Port Replacement: 13 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 13 단계, 이미지 2/2
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 Charging Port Replacement, LCD Screen: 14 단계, 이미지 1/3 Motorola MC5590 Charging Port Replacement, LCD Screen: 14 단계, 이미지 2/3 Motorola MC5590 Charging Port Replacement, LCD Screen: 14 단계, 이미지 3/3
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 Charging Port Replacement: 15 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 15 단계, 이미지 2/2
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 Charging Port Replacement: 16 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 16 단계, 이미지 2/2
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 Charging Port Replacement: 17 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement: 17 단계, 이미지 2/2
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
  18. Motorola MC5590 Charging Port Replacement, Internal Antenna: 18 단계, 이미지 1/2 Motorola MC5590 Charging Port Replacement, Internal Antenna: 18 단계, 이미지 2/2
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
  19. Motorola MC5590 Charging Port Replacement, Charging Port: 19 단계, 이미지 1/1
    • Remove the 2 screws (3 mm long) at the bottom of the motherboard using a PH00-bit screwdriver.
    • Disconnect the charging port from the rest of the device.
결론
Tyler Jean
회원 가입일: 02/22/18
555 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G6, Cagle Spring 2018 USF Tampa, Team S1-G6, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 13
전체 시간: 312
