주요 콘텐츠로 건너뛰기
Motorola MOTO W755 Cell Phone Key Pad Cover Replacement
필요한 것
  1. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement, Main Logic Board: 1 단계, 이미지 1/1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  2. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 2 단계, 이미지 1/2 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  3. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 3 단계, 이미지 1/3 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 3 단계, 이미지 2/3 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 3 단계, 이미지 3/3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  4. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 4 단계, 이미지 1/1
    • Remove the plastic covering completely from the body of the phone.
  5. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 5 단계, 이미지 1/2 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
  6. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement, Key Pad Cover: 6 단계, 이미지 1/1
    • After removing the main logic board, use the plastic opening tool to poke from the back and peel off the key pad cover.
결론
Roberta Glenn
회원 가입일: 07/11/12
43 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 회원
CPSU-REGAN-SU12S1G3
2 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 1,224
