주요 콘텐츠로 건너뛰기
Motorola MOTO W755 Cell Phone Top Panel Replacement
필요한 것
  1. Motorola MOTO W755 Cell Phone Top Panel Replacement, Battery: 1 단계, 이미지 1/2 Motorola MOTO W755 Cell Phone Top Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Top Panel Replacement: 2 단계, 이미지 1/2 Motorola MOTO W755 Cell Phone Top Panel Replacement: 2 단계, 이미지 2/2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: 3 단계, 이미지 1/3 Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: 3 단계, 이미지 2/3 Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: 3 단계, 이미지 3/3
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  4. Motorola MOTO W755 Cell Phone Top Panel Replacement: 4 단계, 이미지 1/3 Motorola MOTO W755 Cell Phone Top Panel Replacement: 4 단계, 이미지 2/3 Motorola MOTO W755 Cell Phone Top Panel Replacement: 4 단계, 이미지 3/3
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  5. Motorola MOTO W755 Cell Phone Top Panel Replacement: 5 단계, 이미지 1/2 Motorola MOTO W755 Cell Phone Top Panel Replacement: 5 단계, 이미지 2/2
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  6. Motorola MOTO W755 Cell Phone Top Panel Replacement: 6 단계, 이미지 1/1
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  7. Motorola MOTO W755 Cell Phone Top Panel Replacement: 7 단계, 이미지 1/1
    • You now have the top panel completely detached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roberta Glenn
회원 가입일: 07/11/12
43 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 회원
CPSU-REGAN-SU12S1G3
2 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,921
