주요 콘텐츠로 건너뛰기
Motorola Moto 360 LCD Display Replacement
필요한 것
  1. Motorola Moto 360 LCD Display Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 LCD Display Replacement: 3 단계, 이미지 1/2 Motorola Moto 360 LCD Display Replacement: 3 단계, 이미지 2/2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 LCD Display Replacement: 4 단계, 이미지 1/1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 LCD Display Replacement, O-Ring: 5 단계, 이미지 1/2 Motorola Moto 360 LCD Display Replacement, O-Ring: 5 단계, 이미지 2/2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 LCD Display Replacement: 6 단계, 이미지 1/1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
  6. Motorola Moto 360 LCD Display Replacement, LCD Display: 7 단계, 이미지 1/1
    • Set the Moto 360 face up on a flat surface.
    • Place the iOpener on the face of the device screen.
  7. Motorola Moto 360 LCD Display Replacement: 8 단계, 이미지 1/2 Motorola Moto 360 LCD Display Replacement: 8 단계, 이미지 2/2
    • Gently slide the opening pick between the screen and the metal casing.
    • Work your way around the face of the screen, loosening the adhesive.
  8. Motorola Moto 360 LCD Display Replacement: 9 단계, 이미지 1/2 Motorola Moto 360 LCD Display Replacement: 9 단계, 이미지 2/2
    • Detach the copper ribbon connecting the motherboard to the display.
    • For reassembly, attach copper ribbon where it is marked.
    • The copper ribbon is fragile and easily disconnects. Remember where it goes so as to reconnect it properly.
  9. Motorola Moto 360 LCD Display Replacement: 10 단계, 이미지 1/1
    • Slide the display out of the metal casing.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Cole Twitchell
회원 가입일: 01/30/15
1,688 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G32
4 회원들
안내서 18개 작성하였습니다
댓글 7개
Good morning,
It is possible to replace the display unit for the Moto 360 2nd with 1.56" display?
Thanks in advance and best regards,
Stephan
Stephan Müller - 답글
Were could i buy a new lcd screen for the moto 360 1st gen??
Sebastian Galvan - 답글
hey mate you can buy one from aliexpress aliexpress moto 360 screen see link below
https://goo.gl/ZSMTVW
Faddy Oraha -
Where can I get a LCD display for a Moto 360 2 gen 42mm. Thanks hope you can help
Glenn Patoska - 답글
Bonjour,
Où est-il possible de trouver des pièces détachées ?
Le fond du boitier.
Merci de votre réponse.
DOGUE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 21,456
