주요 콘텐츠로 건너뛰기
Motorola Moto 360 O-Ring Replacement
필요한 것
  1. Motorola Moto 360 O-Ring Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 O-Ring Replacement: 3 단계, 이미지 1/2 Motorola Moto 360 O-Ring Replacement: 3 단계, 이미지 2/2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 O-Ring Replacement: 4 단계, 이미지 1/1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 O-Ring Replacement, O-Ring: 5 단계, 이미지 1/2 Motorola Moto 360 O-Ring Replacement, O-Ring: 5 단계, 이미지 2/2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 O-Ring Replacement: 6 단계, 이미지 1/1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jake Steinorth
회원 가입일: 01/30/15
149 평판
안내서 1개 작성함
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G32
4 회원들
안내서 18개 작성하였습니다
댓글 3개
Where can you get your hands on a replacement o'ring?!
James S - 답글
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - 답글
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 2,696
