소개
Use this guide to replace the motherboard on your Motorola Moto E.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
다른 29명이 해당 안내서를 완성하였습니다.
댓글 7개
In step 8, after pulling the black cable out, how do you insert it in the new motherboard again? I doesn't go in. There's a plastic clamp inside that too. How does one remove the outer metal box?
Where should I find a new logic board? Motorola Moto E XT1022
Hi my moto e board not showing signal
Where to get the new motherboard from?
Hello All,
I wanted to repair my moto e too. >At first I thought the problem is the battery as the phone was not charging and so I removed the case and connected the phone without the battery to the chrager expecting it to boot up. But this does not seem to be the problem as there is no change in the status of the phone. How do I isolate the problem as a first step.
Thanks,
