주요 콘텐츠로 건너뛰기
Motorola Moto E Motherboard Replacement
필요한 것
  1. Motorola Moto E Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Motherboard Replacement: 3 단계, 이미지 1/1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Motherboard Replacement: 4 단계, 이미지 1/1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Motherboard Replacement: 5 단계, 이미지 1/1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Motherboard Replacement: 6 단계, 이미지 1/1
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Motherboard Replacement: 7 단계, 이미지 1/1
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Motherboard Replacement: 8 단계, 이미지 1/2 Motorola Moto E Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Motherboard Replacement: 9 단계, 이미지 1/1
    • Using the metal spudger, pry the motherboard away from the screen assembly.
결론
다른 29명이 해당 안내서를 완성하였습니다.
Alex Craig
회원 가입일: 03/11/15
2,578 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 회원
UCCS-PANKO-S15S5G7
2 회원들
안내서 10개 작성하였습니다
댓글 7개
In step 8, after pulling the black cable out, how do you insert it in the new motherboard again? I doesn't go in. There's a plastic clamp inside that too. How does one remove the outer metal box?
Ritwik Joshi - 답글
Where should I find a new logic board? Motorola Moto E XT1022
Abhijith Palur - 답글
Hi my moto e board not showing signal
Mehraj Udin Dar - 답글
Where to get the new motherboard from?
HIM SHIKHAR BISWAS - 답글
Hello All,
I wanted to repair my moto e too. >At first I thought the problem is the battery as the phone was not charging and so I removed the case and connected the phone without the battery to the chrager expecting it to boot up. But this does not seem to be the problem as there is no change in the status of the phone. How do I isolate the problem as a first step.
Thanks,
Psp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 23,315
