소개
You will need to remove the outer back plastic cover and the battery connection in order to access the motherboard and camera parts to do the replacement.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
다른 2명이 해당 안내서를 완성하였습니다.
