주요 콘텐츠로 건너뛰기
Motorola Moto E Rear Facing Camera Replacement
필요한 것
  1. Motorola Moto E Rear Facing Camera Replacement, Motherboard: 1 단계, 이미지 1/1
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Rear Facing Camera Replacement: 2 단계, 이미지 1/1
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Rear Facing Camera Replacement: 5 단계, 이미지 1/1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Rear Facing Camera Replacement: 6 단계, 이미지 1/1
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Rear Facing Camera Replacement: 7 단계, 이미지 1/1
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Rear Facing Camera Replacement: 8 단계, 이미지 1/2 Motorola Moto E Rear Facing Camera Replacement: 8 단계, 이미지 2/2
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Rear Facing Camera Replacement: 9 단계, 이미지 1/1
    • Using the metal spudger, pry the motherboard away from the screen assembly.
  10. Motorola Moto E Rear Facing Camera Replacement, Rear Facing Camera: 10 단계, 이미지 1/1
    • Use the plastic opening tool to pry the metal housing off.
  11. Motorola Moto E Rear Facing Camera Replacement: 11 단계, 이미지 1/1
    • Remove the rubber cover on the camera by gently lifting it up.
  12. Motorola Moto E Rear Facing Camera Replacement: 12 단계, 이미지 1/1
    • Use the same plastic opening tool to pry the camera assembly off.
    • Use the plastic opening tool on all four sides of the camera several times until it starts to come loose.
  13. Motorola Moto E Rear Facing Camera Replacement: 13 단계, 이미지 1/1
    • Pull the camera assembly out.
    • Place the new camera assembly into the connector and press gently.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alex Craig
회원 가입일: 03/11/15
2,578 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 회원
UCCS-PANKO-S15S5G7
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 3,158
