소개
In order to access the volume and power buttons for replacement, you need to completely disassemble the device. Pay special attention to the directions the buttons are facing because they only fit one way.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
Locate the 3 tabs on the backs of the volume and power buttons.
Press firmly on the tabs using the plastic spudger until they pop out.
다른 9명이 해당 안내서를 완성하였습니다.
