소개
Use this guide to remove or replace a battery in your Moto E4.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
This guide can also be used to gain access to the SIM card slot and the micro SD card slot.
필요한 것
Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
With the phone face down, lift the battery up by the labeled tab and remove it from the device.
다른 4명이 해당 안내서를 완성하였습니다.
