주요 콘텐츠로 건너뛰기
Motorola Moto E4 Front Facing Camera Replacement
필요한 것
  1. Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: 1 단계, 이미지 2개 중 1개 Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: 1 단계, 이미지 2개 중 2개
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: 2 단계, 이미지 2개 중 1개 Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: 2 단계, 이미지 2개 중 2개
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto E4 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 2개 중 1개 Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 2개 중 2개
    • Detach the front facing cable ribbon connector using an iFixit opening tool and lift the camera out of position.
    • To completely remove the front facing camera from the phone, the copper colored adhesive must be torn. The camera will still with the adhesive removed, but there may be unknown side effects.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nate Tjepkema
회원 가입일: 01/24/19
1,275 평판
안내서 7개를 작성함
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 회원
CPSU-WHITE-W19S2G4
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 586
