소개
Use this guide to remove the Moto E4 motherboard cover. Doing so allows access to the front facing camera, the rear facing camera, and the motherboard.
필요한 것
Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
With the phone face down, lift the battery up by the labeled tab and remove it from the device.
Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
다른 2명이 해당 안내서를 완성하였습니다.
