소개
If there is any problem with the phone that you plan to repair, removing the battery is the first step in completing the repairs and is critical for safety while working on the phone.
If your battery is swollen, take appropriate precautions.
Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
my moto e4 plus screen is freezing , how can we unfreeze please advise
This is the only tutorial that looks like my phone inside, even tho they’re all supposed to be Moto E4 Plus. All the ones on YouTube look different, screws in different places, etc.
Hi Brad,
Motorola released a few variants of Moto E4s. You can compare phone’s model number to figure out exactly which model you have. We unfortunately don’t have all the Motorola guides covered at this point, but we’re working on it!
