주요 콘텐츠로 건너뛰기
Motorola Moto E4 Plus Battery Replacement
필요한 것
  1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 1 단계, 이미지 1/3 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 1 단계, 이미지 2/3 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Battery Replacement: 2 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 2 단계, 이미지 2/2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Battery Replacement, Remove the midframe screws: 3 단계, 이미지 1/1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Battery Replacement, Release the midframe clips: 4 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement, Release the midframe clips: 4 단계, 이미지 2/2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Battery Replacement, Remove the midframe: 5 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement, Remove the midframe: 5 단계, 이미지 2/2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Battery Replacement, Disconnect the battery: 6 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement, Disconnect the battery: 6 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Battery Replacement, Battery adhesives: 7 단계, 이미지 1/3 Motorola Moto E4 Plus Battery Replacement, Battery adhesives: 7 단계, 이미지 2/3 Motorola Moto E4 Plus Battery Replacement, Battery adhesives: 7 단계, 이미지 3/3
    • If your battery has two black tabs near the bottom corners, the battery is held in place by stretch-release adhesives. If that's the case, follow this guide instead to complete your battery replacement.
    • Before you begin prying, note that the battery is held in place by two adhesive strips.
  8. Motorola Moto E4 Plus Battery Replacement, Loosen the battery: 8 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement, Loosen the battery: 8 단계, 이미지 2/2
    • Insert an opening pick into the top right edge of the battery.
    • Push the opening pick in carefully until half of the pick is under the battery.
  9. Motorola Moto E4 Plus Battery Replacement: 9 단계, 이미지 1/1
    • Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol along the right edge of the battery.
    • Tilt the edge up slightly for a minute to allow the isopropyl alcohol to soften the adhesive.
  10. Motorola Moto E4 Plus Battery Replacement: 10 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 10 단계, 이미지 2/2
    • As you slice through the adhesive with the opening pick, try your best not to bend the battery pack. Soft shell lithium-ion batteries are highly susceptible to damage and can ignite when compromised.
    • Insert another opening pick into the right edge, near the first opening pick.
    • Slide the opening pick down along the right edge to loosen the right adhesive strip.
    • If the slicing feels difficult, apply a few more drops of isopropyl alcohol into the edge, wait a minute for it to seep in, and try again.
  11. Motorola Moto E4 Plus Battery Replacement: 11 단계, 이미지 1/1
    • Insert an opening pick into the bottom left edge of the battery.
    • Push the opening pick until it is halfway under the battery.
    • Apply isopropyl alcohol along the left edge and let it sit for a minute to weaken the adhesive.
  12. Motorola Moto E4 Plus Battery Replacement: 12 단계, 이미지 1/2 Motorola Moto E4 Plus Battery Replacement: 12 단계, 이미지 2/2
    • Grasp the battery along the right corners and slowly lift the right edge upwards.
    • If the battery begins to bend significantly, stop and re-apply more isopropyl alcohol to the left adhesive strip.
  13. Motorola Moto E4 Plus Battery Replacement: 13 단계, 이미지 1/1
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a replacement battery:
    • Remove the old adhesive from the phone frame.
    • Apply new adhesive in the same general area as the old adhesive.
    • Lay the battery lightly in place. Check that the battery connector is properly aligned with its motherboard socket.
    • Press the battery firmly into the phone for thirty seconds.
결론
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,729 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
You are a star. Spot on. I very much appreciate your contribution in breaking the monopoly of the bastards. They sold me the mobile without telling me the battery is fixed. I was about to send it for repair on their lab which could have cost me at least £200 if not more. £25 DHL . £45 just for looking into it . This is even before replacing the battery and the cost of labor. Take off my hat for you. Keep up the good work.
best regards
Sburgess
SALWAN BURGESS - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 35
전체 시간: 4,440
