소개
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
This relatively moderate guide will walk you through with replacing the motherboard of your device. Sit tight as you'll be spending some time unscrewing a lot of screws and disconnecting connectors.
필요한 것
Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
Fold the copper tape out of the way.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 2개
guide states that there are 17 screws to remove (step 2) but there are 20 screws circled… Counting is hard I guess?
From step 9 it’s another phone. I’m guessing E4 (regular) but they are not the same. The vibration motor, second sim tray, and many other components disappear suddenly. Mixing different phones is very irresponsable and lazy.
