주요 콘텐츠로 건너뛰기
Motorola Moto E4 Rear Facing Camera Replacement
필요한 것
  1. Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: 1 단계, 이미지 2개 중 1개 Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: 1 단계, 이미지 2개 중 2개
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: 2 단계, 이미지 2개 중 1개 Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: 2 단계, 이미지 2개 중 2개
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Rear Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto E4 Rear Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Motorola Moto E4 Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Motorola Moto E4 Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nate Tjepkema
회원 가입일: 01/24/19
1,275 평판
안내서 7개를 작성함
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 회원
CPSU-WHITE-W19S2G4
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 869
