주요 콘텐츠로 건너뛰기
Motorola Moto E4 Screen Assembly Replacement
필요한 것
  1. Motorola Moto E4 Screen Assembly Replacement, Back Cover: 1 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement, Back Cover: 1 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move to the bottom left corner to pry the phone out of the back cover.
  2. Motorola Moto E4 Screen Assembly Replacement: 2 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 2 단계, 이미지 2/2
    • Lift the phone out of the back cover.
  3. Motorola Moto E4 Screen Assembly Replacement, Battery: 3 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement, Battery: 3 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement, Battery: 3 단계, 이미지 3/3
    • Use a fingernail or spudger to pry at the notch at the bottom end of the battery.
    • Lever the battery out of its recess and remove it.
  4. Motorola Moto E4 Screen Assembly Replacement, Loudspeaker: 4 단계, 이미지 1/1
    • Remove the six 3.3 mm long Phillips #00 screws.
  5. Motorola Moto E4 Screen Assembly Replacement: 5 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 5 단계, 이미지 2/2
    • Insert an opening pick between the loudspeaker and the frame to pry it up by twisting the opening pick.
    • Remove the loudspeaker unit.
  6. Motorola Moto E4 Screen Assembly Replacement, Motherboard Cover: 6 단계, 이미지 1/1
    • Remove the seven 3.3 mm Phillips #00 screws.
  7. Motorola Moto E4 Screen Assembly Replacement: 7 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 7 단계, 이미지 2/2
    • Insert an opening pick between the cover and the motherboard at the bottom right corner.
    • Slide the opening pick upwards to open the plastic clips.
  8. Motorola Moto E4 Screen Assembly Replacement: 8 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 8 단계, 이미지 2/2
    • Insert an opening pick between the cover and the motherboard at the bottom left corner.
    • Pry up the motherboard cover by twisting the opening pick.
  9. Motorola Moto E4 Screen Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the motherboard cover.
  10. Motorola Moto E4 Screen Assembly Replacement, Motherboard Assembly: 10 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement, Motherboard Assembly: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to peel off the yellow tape of the ZIF connector located on the left of the motherboard.
  11. Motorola Moto E4 Screen Assembly Replacement: 11 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 11 단계, 이미지 2/2
    • Use the edge of a spudger to open the black flap of the ZIF connector.
  12. Motorola Moto E4 Screen Assembly Replacement: 12 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 12 단계, 이미지 2/2
    • Slide the volume button flex cable out of the ZIF connector to disconnect it.
  13. Motorola Moto E4 Screen Assembly Replacement: 13 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 13 단계, 이미지 2/2
    • Use a pair of tweezers to pry up and disconnect the antenna cable located on the left of the motherboard.
    • Fold the antenna cable out of the way.
  14. Motorola Moto E4 Screen Assembly Replacement: 14 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 14 단계, 이미지 2/2
    • Use the edge of a spudger to pry up and disconnect the display flex cable located on the bottom left of the motherboard.
  15. Motorola Moto E4 Screen Assembly Replacement: 15 단계, 이미지 1/1
    • Remove the two 2.9 mm long Phillips #00 screws securing the motherboard.
  16. Motorola Moto E4 Screen Assembly Replacement: 16 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 16 단계, 이미지 2/2
    • Don't try to remove the motherboard all the way yet. The interconnect flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard from the top and fold it towards the battery compartment.
    • Be careful not to damage any components underneath the motherboard.
  17. Motorola Moto E4 Screen Assembly Replacement: 17 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement: 17 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement: 17 단계, 이미지 3/3
    • Use the edge of a spudger to disconnect the interconnect cable from the motherboard.
    • Remove the motherboard.
  18. Motorola Moto E4 Screen Assembly Replacement, Charging Board: 18 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement, Charging Board: 18 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
  19. Motorola Moto E4 Screen Assembly Replacement: 19 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 19 단계, 이미지 2/2
    • Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
  20. Motorola Moto E4 Screen Assembly Replacement: 20 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 20 단계, 이미지 2/2
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  21. Motorola Moto E4 Screen Assembly Replacement: 21 단계, 이미지 1/1
    • Remove the 2.9 mm long Phillips #00 screw securing the daughterboard.
  22. Motorola Moto E4 Screen Assembly Replacement: 22 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 22 단계, 이미지 2/2
    • Pry under the bottom end of the charging board and lift it upwards.
    • Remove the charging board.
  23. Motorola Moto E4 Screen Assembly Replacement, Earpiece Speaker: 23 단계, 이미지 1/1
    • Apply a heated iOpener for about one minute to the upper part of the display to loosen the adhesive beneath the earpiece speaker.
  24. Motorola Moto E4 Screen Assembly Replacement: 24 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 24 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to lift the earpiece speaker out of its recess and remove it.
    • When reassembling, be sure to properly orient the earpiece speaker such that the gold contacts are pointing away from the top edge.
  25. Motorola Moto E4 Screen Assembly Replacement, Screen Assembly: 25 단계, 이미지 1/1
    • Apply a heated iOpener to the left edge of the phone for about 30 seconds to loosen the adhesive beneath power and volume button unit.
  26. Motorola Moto E4 Screen Assembly Replacement: 26 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement: 26 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement: 26 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to gently peel the power and volume button unit off the left edge of the phone.
    • Remove the power and volume button unit.
  27. Motorola Moto E4 Screen Assembly Replacement: 27 단계, 이미지 1/1
    • Apply the iOpener for about two minutes on the black adhesive tape that covers the antenna and the interconnect cable.
  28. Motorola Moto E4 Screen Assembly Replacement: 28 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement: 28 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement: 28 단계, 이미지 3/3
    • Use a pair of tweezers to gently peel the adhesive tape off the antenna and interconnect cable and fold it out of the way.
  29. Motorola Moto E4 Screen Assembly Replacement: 29 단계, 이미지 1/2 Motorola Moto E4 Screen Assembly Replacement: 29 단계, 이미지 2/2
    • Use a pair of tweezers to thread the antenna cable out of its routing.
    • Remove the antenna cable.
  30. Motorola Moto E4 Screen Assembly Replacement: 30 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement: 30 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement: 30 단계, 이미지 3/3
    • Use a pair of tweezers to gently peel the product sticker off the interconnect cable.
    • In case you can't remove the sticker or it starts to rip apart you can re-apply an iOpener to loosen the adhesive.
  31. Motorola Moto E4 Screen Assembly Replacement: 31 단계, 이미지 1/3 Motorola Moto E4 Screen Assembly Replacement: 31 단계, 이미지 2/3 Motorola Moto E4 Screen Assembly Replacement: 31 단계, 이미지 3/3
    • Use a pair of tweezers to grab and carefully peel up the interconnect flex cable.
    • Remove the interconnect flex cable.
  32. Motorola Moto E4 Screen Assembly Replacement: 32 단계, 이미지 1/1
    • Check your replacement part for any other components that might need to be transferred before reassembly.
결론
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
다른 3명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
118,058 평판
안내서 189개 작성하였습니다
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,086개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 19
전체 시간: 3,350
