소개
Follow this guide to replace the screen for the Motorola Moto E5 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge your existing battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
필요한 것
Insert your fingernail or the flat end of a spudger into the notch on the bottom right corner of the phone.
Pry with your fingernail or twist the spudger to release the back cover's clips from the phone.
Insert your fingernail or the flat end of the spudger into the notch at the bottom of the battery.
Pry with your fingernail or spudger to free the battery from its recess.
이 단계에 사용된 도구:Tweezers$4.99
Remove the thirteen 3.5 mm-long T5 Torx screws securing the motherboard and daughterboard covers to the phone's frame.
Repair didn’t go as planned? Check out our Motorola Moto E5 Play Answers community for troubleshooting help.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 6개
How do i get the screen out of the frame?
It’s all one component! I suppose it’s possible to separate them, but the part we sell includes the screen and the frame in one piece.
Yup, screen and frame comes as one piece. Just completed!
Do I need any adhesive to put it on the new frame? If so, what type and where does it go? Thanks!
