주요 콘텐츠로 건너뛰기
Motorola Moto E6 Battery Replacement
필요한 것
  1. Motorola Moto E6 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto E6 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Battery Replacement, Battery: 2 단계, 이미지 1/1
    • Use the opening tool on the divot located below the battery to pop it out.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Matthew Zelten
회원 가입일: 01/23/20
471 평판
안내서 3개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2020 Cal Poly, Team S2-G3, White Winter 2020 회원
CPSU-WHITE-W20S2G3
4 회원들
안내서 10개 작성하였습니다
댓글 3개
When I try to power my phone on, it shows a robot and words. How do I fix this?
Da QBee - 답글
If I had known it’d take two steps I would have put the new battery in weeks ago! lol Currently waiting for the phone to dip under 10% before charging it. The steps are very easy and understandable.
Oh I want everyone to be aware this tool plastic opening tool, the ends are sharp! I was very lucky it wasn’t deep, just very shallow. I used a towel so I don’t scratch the table and keep the phone safe since it has glass.
I’ll report back once the battery fully charges. I hope it goes well! I need the phone working because it’s the only phone I have.
Donna Baillod - 답글
Who’s got great advice on opening super-stubborn case? Trying a few different plastic pry tools. (:-( (One is showing signs of plastic stress.)
Doug Grinbergs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 116
전체 시간: 4,761
