주요 콘텐츠로 건너뛰기
Motorola Moto E6 Charging Dock Replacement
필요한 것
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto E6 Charging Dock Replacement, Back Cover: 1 단계, 이미지 2/2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: 2 단계, 이미지 1/1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: 3 단계, 이미지 1/1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: 4 단계, 이미지 1/1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: 5 단계, 이미지 1/1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: 6 단계, 이미지 1/1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Matthew Zelten
회원 가입일: 01/23/20
471 평판
안내서 3개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2020 Cal Poly, Team S2-G3, White Winter 2020 회원
CPSU-WHITE-W20S2G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 25
전체 시간: 2,895
