소개
This guide shows how to replace the motherboard in the Motorola Moto E6. It should be replaced if it gets damaged or exposed to water. The motherboard also contains the SIM card port and the auxiliary plug.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
다른 한 분이 해당 안내서를 완성하였습니다.
