소개
The inner circuit board covers inside the Motorola Moto E6 Play phone protect the two circuit boards, including the motherboard. They need to be removed in order to access several different components of the phone, including both cameras, the fingerprint scanner, and the battery.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
이 단계에 사용된 도구:Halberd Spudger$2.99
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
이 단계에 사용된 도구:Tweezers$3.99
With the angled tweezers, remove the black cover to reveal the motherboard underneath.
