주요 콘텐츠로 건너뛰기
Motorola Moto E6 Speaker Replacement
필요한 것
  1. Motorola Moto E6 Speaker Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto E6 Speaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Speaker Replacement, Battery: 2 단계, 이미지 1/1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Speaker Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Speaker Replacement: 5 단계, 이미지 1/3 Motorola Moto E6 Speaker Replacement: 5 단계, 이미지 2/3 Motorola Moto E6 Speaker Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, lift the speaker from the motherboard located at the top of the device.
    • When replacing with a new component, make sure the clips are facing towards the user.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,180
