주요 콘텐츠로 건너뛰기
  1. Before you start following any of the steps of this guide, completely turn the device off. Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port Remove any installed SIM card and memory microSD cards.
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
    • Remove any installed SIM card and memory microSD cards.
    • Push the SIM card into the phone, and the spring eject mechanism should release the card.
    • The microSD memory card(s) may not have an eject mechanism. If so, they must be removed carefully by pushing on the raised edge/bump that is built onto the card. Use your fingernail or a plastic or rubber tool, but not one that will scratch and damage the delicate card.
    • Patience must be taken to prevent irreversible damage and loss of data on the card.
  2. Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
    Warning: The SIM card and microSD memory cards MUST BE REMOVED to complete the next step (Step 3 Battery Cover).
    If they are not removed before prying away the battery cover, they may be damaged, and important data may be destroyed (cannot be recovered)!!
    Failure to remove them will also make removing the battery cover in Step 3 difficult, if not impossible.
    FixWiki - 답글
  3. Use a plastic opening tool to remove the  protective cover. Carefully work the plastic tool around all the edges of the phone.
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Disconnect the connection between the Battery and the Mother Board by using the Pry tool. Disconnect the connection between the Battery and the Mother Board by using the Pry tool.
    • Disconnect the connection between the Battery and the Mother Board by using the Pry tool.
  5. With the battery already disconnected,work around its edge with the pry tool to remove it from the assembly. The battery is attached with a sticker, so it may take some work to pry up. Just work at it slowly and carefully until you get it.
    • With the battery already disconnected,work around its edge with the pry tool to remove it from the assembly.
    • The battery is attached with a sticker, so it may take some work to pry up. Just work at it slowly and carefully until you get it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Radostin Lobodov
회원 가입일: 2014년 10월 16일
2,841 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G7
3 회원들
안내서 6개 작성하였습니다
Hello!
I have just completed this operation. I would like you to know that my Moto G 1st Generation needed a T4 Torx screwdriver.
Other than that, everything went fine!
Best Wishes,
Bubba G
Bubba G - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 3,926
