주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Before you start following any of the steps of this guide, completely turn the device off. Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Use a plastic opening tool to remove the protective cover. Carefully work the plastic tool around all the edges of the phone.
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard. You want to pry up the black tab that locks it in place. It may be under a protective sticker.
    • Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard.
    • You want to pry up the black tab that locks it in place. It may be under a protective sticker.
    • Though the battery is removed in our second photo, it is not required for removing the front camera.
  5. Remove the camera from the phone by using the tweezers. To reassemble, follow the steps in reverse.
    • Remove the camera from the phone by using the tweezers.
    • To reassemble, follow the steps in reverse.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Radostin Lobodov
회원 가입일: 2014년 10월 16일
2,841 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G7
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,230
