주요 콘텐츠로 건너뛰기
Motorola Moto G 1st Generation Headphone Jack Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: 1 단계, 이미지 1/3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: 1 단계, 이미지 2/3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: 1 단계, 이미지 3/3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Screws: 2 단계, 이미지 1/1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: 3 단계, 이미지 1/2 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: 3 단계, 이미지 2/2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: 4 단계, 이미지 1/3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: 4 단계, 이미지 2/3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: 4 단계, 이미지 3/3
    • Use the plastic opening tool to remove the Headphone Jack from the protective cover and replace it.
결론
Radostin Lobodov
회원 가입일: 10/16/14
2,904 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 2,382
