주요 콘텐츠로 건너뛰기
Motorola Moto G 1st Generation Midframe Replacement
필요한 것
  1. Motorola Moto G 1st Generation Midframe Replacement, Removing the Cover: 1 단계, 이미지 1/3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Cover: 1 단계, 이미지 2/3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Cover: 1 단계, 이미지 3/3
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Motorola Moto G 1st Generation Midframe Replacement: 2 단계, 이미지 1/1
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
    • In some version of this phone, a microSD memory card can be installed. If so, you must also remove these cards.
    • Be careful as to not damage the microSD memory card. Unlike the SIM card, pushing this in may not spring release, as there may not be an eject mechanism.
    • If there is no spring release eject mechanism, hopefully your microSD card has a ridge/raised edge that you can push on with your fingernail or plastic/rubber tool to push the card out. This may be difficult - be patient and do not use excessive force/sharp tools that could cause permanent damage and permanent loss of data.
  3. Motorola Moto G 1st Generation Midframe Replacement, Removing the Back Plate: 3 단계, 이미지 1/3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Back Plate: 3 단계, 이미지 2/3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Back Plate: 3 단계, 이미지 3/3
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
  4. Motorola Moto G 1st Generation Midframe Replacement, The Inside of your Phone: 4 단계, 이미지 1/3 Motorola Moto G 1st Generation Midframe Replacement, The Inside of your Phone: 4 단계, 이미지 2/3 Motorola Moto G 1st Generation Midframe Replacement, The Inside of your Phone: 4 단계, 이미지 3/3
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Rebecca Montgomery
회원 가입일: 09/25/14
3,982 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-6, Brown Fall 2014 USF Tampa, Team 1-6, Brown Fall 2014 회원
USFT-BROWN-F14S1G6
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 3,695
