소개
This guide shows you how to replace the speaker on a Motorola Moto G 1st Generation smartphone.
필요한 것
1 단계 Rear Panel
주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use the plastic opening tool to remove the Speaker from the protective cover.
다른 2명이 해당 안내서를 완성하였습니다.
