이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Follow this guide, and you will be able to replace the front camera in your Moto G, in the event that it breaks or malfunctions. The part itself is simple to remove, but getting to it make take some time and care. You will need a T5 Torx screwdriver and a plastic opening tool.
필요한 것
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
다른 9명이 해당 안내서를 완성하였습니다.
