소개
This guide will teach you how to replace the motherboard in your Moto G, in the event that it is malfunctioning. It may take a while, since the battery and SD/SIM card reader must be removed first, but all you will need are a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
다른 30명이 해당 안내서를 완성하였습니다.
댓글 4개
What about Android, it comes already flashed on a new motherboard or I need to flash it myself?
Where can i buy mother board for moto g 2nd gen lte. Any idea?
