주요 콘텐츠로 건너뛰기
Motorola Moto G 2nd gen. 2014 Battery Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Motorola Moto G 2nd gen. 2014 Battery Replacement, Battery and SIM&SD Card Reader: 1 단계, 이미지 1/2 Motorola Moto G 2nd gen. 2014 Battery Replacement, Battery and SIM&SD Card Reader: 1 단계, 이미지 2/2
    • Remove back cover.
  2. Motorola Moto G 2nd gen. 2014 Battery Replacement: 2 단계, 이미지 1/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 2 단계, 이미지 2/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 2 단계, 이미지 3/3
    • Unscrew 14 screws and remove the back frame.
  3. Motorola Moto G 2nd gen. 2014 Battery Replacement: 3 단계, 이미지 1/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 3 단계, 이미지 2/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 3 단계, 이미지 3/3
    • Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator.
  4. Motorola Moto G 2nd gen. 2014 Battery Replacement: 4 단계, 이미지 1/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 4 단계, 이미지 2/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 4 단계, 이미지 3/3
    • Loosen kinds of stickers fastening card reader assembly and battery.
  5. Motorola Moto G 2nd gen. 2014 Battery Replacement: 5 단계, 이미지 1/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 5 단계, 이미지 2/3 Motorola Moto G 2nd gen. 2014 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly.
  6. Motorola Moto G 2nd gen. 2014 Battery Replacement: 6 단계, 이미지 1/1
    • The battery can be replaced now.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 9개
Hola, donde se puede comprar el reemplazo para el slot Sim-card del Moto G 2014 segunda generación?
Renzo Diaz - 답글
Where can I get the replacement battery?
David - 답글
Ebay, Aliexpress, Amazon, etc.
Example : http://www.amazon.com/MOTOROLA-2070mAh-L...
Just look at the reference on your removed battery, and order the same.
Xavier -
Battery Problem battery fast charge & fast low
PAWAN VISHWAKARMA - 답글
What is the Mobile
VijayMani - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 9
전체 시간: 21,539
