주요 콘텐츠로 건너뛰기
Motorola Moto G 5G (2022) Back Cover Replacement
필요한 것
  1. Motorola Moto G 5G (2022) Back Cover Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Back Cover Replacement, Remove the SIM card tray: 2 단계, 이미지 1개 중 1개
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Back Cover Replacement, Back cover removal information: 3 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Back cover removal information: 3 단계, 이미지 2개 중 2개
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Back Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Back Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Back Cover Replacement, Release the right clips: 5 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Release the right clips: 5 단계, 이미지 2개 중 2개
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Back Cover Replacement, Release the bottom clips: 6 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Release the bottom clips: 6 단계, 이미지 2개 중 2개
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Back Cover Replacement, Release the left clips: 7 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Release the left clips: 7 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Back Cover Replacement, Release the left clips: 7 단계, 이미지 3개 중 3개
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Back Cover Replacement, Release the top clips: 8 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Release the top clips: 8 단계, 이미지 2개 중 2개
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Back Cover Replacement: 9 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement: 9 단계, 이미지 2개 중 2개
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Back Cover Replacement, Remove the back cover: 10 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Remove the back cover: 10 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Back Cover Replacement, Remove the back cover: 10 단계, 이미지 3개 중 3개
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Back Cover Replacement, Remove the power button: 11 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Back Cover Replacement, Remove the power button: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Back Cover Replacement, Only the back cover remains: 12 단계, 이미지 1개 중 1개
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
1가이드 댓글
What adhesive is used?
Bill Meakin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 98
전체 시간: 4,521
