주요 콘텐츠로 건너뛰기
Motorola Moto G 5G (2022) Main Camera Replacement
필요한 것
  1. Motorola Moto G 5G (2022) Main Camera Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the SIM card tray: 2 단계, 이미지 1개 중 1개
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Main Camera Replacement, Back cover removal information: 3 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Back cover removal information: 3 단계, 이미지 2개 중 2개
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Main Camera Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Main Camera Replacement, Release the right clips: 5 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Release the right clips: 5 단계, 이미지 2개 중 2개
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Main Camera Replacement, Release the bottom clips: 6 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Release the bottom clips: 6 단계, 이미지 2개 중 2개
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Main Camera Replacement, Release the left clips: 7 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Release the left clips: 7 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Release the left clips: 7 단계, 이미지 3개 중 3개
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Main Camera Replacement, Release the top clips: 8 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Release the top clips: 8 단계, 이미지 2개 중 2개
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Main Camera Replacement: 9 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the back cover: 10 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the back cover: 10 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the back cover: 10 단계, 이미지 3개 중 3개
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the power button: 11 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the power button: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Main Camera Replacement, Only the back cover remains: 12 단계, 이미지 1개 중 1개
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Main Camera Replacement, Unfasten the power button cable bracket: 13 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Unfasten the power button cable bracket: 13 단계, 이미지 2개 중 2개
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the power button cable bracket: 14 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the power button cable bracket: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the power button: 15 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the power button: 15 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the power button: 16 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the power button: 16 단계, 이미지 2개 중 2개
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
  17. Motorola Moto G 5G (2022) Main Camera Replacement, Unfasten the motherboard cover: 17 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Unfasten the motherboard cover: 17 단계, 이미지 2개 중 2개
    • Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  18. Motorola Moto G 5G (2022) Main Camera Replacement, Pry the motherboard cover: 18 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Pry the motherboard cover: 18 단계, 이미지 2개 중 2개
    • Insert an opening pick between the bottom-left corner of the cover and the motherboard.
    • Pry up to release the cover's small clips securing it to the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • Work your way around the perimeter to free the cover if it feels stuck.
  19. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the motherboard cover: 19 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the motherboard cover: 19 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the motherboard cover: 19 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grab and remove the motherboard cover from the phone.
  20. Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the battery: 20 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the battery: 20 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Moto G 5G (2022) Main Camera Replacement, Peel away the tape: 21 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Peel away the tape: 21 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Peel away the tape: 21 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Peel the tape from the display connector.
    • If you are using a pair of tweezers, use caution to avoid the battery.
    • If you're having trouble peeling the tape, heat an iOpener and apply it to the tape for 60 seconds.
  22. Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the display: 22 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the display: 22 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry and disconnect the screen's press connector.
  23. Motorola Moto G 5G (2022) Main Camera Replacement, Lift the graphite film: 23 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Lift the graphite film: 23 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Lift the graphite film: 23 단계, 이미지 3개 중 3개
    • Fold the graphite heat film away from the battery to expose the lower section of the motherboard.
  24. Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the board connector: 24 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the board connector: 24 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry and disconnect the board cable's press connector.
  25. Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the black antenna cable: 25 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the black antenna cable: 25 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the black antenna cable: 25 단계, 이미지 3개 중 3개
    • Use the pointed end of your spudger to pry and disconnect the head of the black antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • Free the cable from the clip below the head of the connector.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
    • During reassembly, make sure to secure the cable to the clip below the head of the connector.
  26. Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the white antenna cable: 26 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Disconnect the white antenna cable: 26 단계, 이미지 2개 중 2개
    • Repeat the previous step for the white antenna cable.
  27. Motorola Moto G 5G (2022) Main Camera Replacement, Unfasten the motherboard: 27 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Unfasten the motherboard: 27 단계, 이미지 2개 중 2개
    • Use your Phillips screwdriver to remove the 2.9 mm-long screw from the bottom-right corner of the motherboard.
  28. Motorola Moto G 5G (2022) Main Camera Replacement, Lift the motherboard: 28 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Lift the motherboard: 28 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Lift the motherboard: 28 단계, 이미지 3개 중 3개
    • Insert the pointed end of a spudger between the lower left of the motherboard and the frame.
    • Lift upward on this bottom edge to free the motherboard from the frame.
  29. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the motherboard: 29 단계, 이미지 2개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the motherboard: 29 단계, 이미지 2개 중 2개
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as its removed.
  30. Motorola Moto G 5G (2022) Main Camera Replacement, Remove the main camera: 30 단계, 이미지 3개 중 1개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the main camera: 30 단계, 이미지 3개 중 2개 Motorola Moto G 5G (2022) Main Camera Replacement, Remove the main camera: 30 단계, 이미지 3개 중 3개
    • Flip the motherboard over so that the lens of the main camera is facing down.
    • Use the pointed end of your spudger to pry and disconnect the main camera's press connector.
    • Remove the main camera from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
1가이드 댓글
Really enjoyed using your ifixit. This made it very easy to replace the camera in my Moto G. Great pictures and descriptions. My Moto G Power was a little different with a fingerprint scanner on the back and integrated side buttons in the frame. The back cover couldn't be folded out of the way until the scanner was disconnected, which couldn't be done until the MOBO cover was removed. Would like to send a pic to show.
Don W - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 62
전체 시간: 644
