주요 콘텐츠로 건너뛰기
Motorola Moto G Power (2020) Battery Replacement
필요한 것
  1. Motorola Moto G Power (2020) Battery Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Position a suction cup securely on the back panel of the device.
    • Insert the opening pick into both sides of the phone and carefully slide it along to open the back panel of the device.
    • Do not fully remove the back panel; disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Apply gentle pressure to the fingerprint sensor with your finger to detach it from the back panel.
    • You may need to apply firm pressure to remove the circular sensor from the panel.
  3. Motorola Moto G Power (2020) Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Fully remove the back panel from the device.
  4. Motorola Moto G Power (2020) Battery Replacement, Fingerprint Sensor: 4 단계, 이미지 1개 중 1개
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
  5. Motorola Moto G Power (2020) Battery Replacement: 5 단계, 이미지 3개 중 1개 Motorola Moto G Power (2020) Battery Replacement: 5 단계, 이미지 3개 중 2개 Motorola Moto G Power (2020) Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
  6. Motorola Moto G Power (2020) Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
  8. Motorola Moto G Power (2020) Battery Replacement, Protective tape: 8 단계, 이미지 1개 중 1개
    • If present, carefully remove the protective tape using a plastic spudger as shown, ensuring the delicate flex cable is not torn in the process.
    • Be careful to not puncture or bend the battery! If punctured, it could start a fire. This is why we recommend discharging your device below 20% before beginning any repairs. Combustion could potentially cause damage to the device and your skin/clothing.
  9. Motorola Moto G Power (2020) Battery Replacement, Disconnect the flex cable: 9 단계, 이미지 2개 중 1개 Motorola Moto G Power (2020) Battery Replacement, Disconnect the flex cable: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a plastic spudger or non-conductive tweezers to disconnect the battery cable from the motherboard.
    • Ensure the tweezers are not pointed or sharp. Be gentle to avoid tearing the flex cable. This could cause a short-circuit in the battery connector, or scratch and damage traces on the motherboard.
  10. Motorola Moto G Power (2020) Battery Replacement, Seperate the old battery from the frame: 10 단계, 이미지 2개 중 1개 Motorola Moto G Power (2020) Battery Replacement, Seperate the old battery from the frame: 10 단계, 이미지 2개 중 2개
    • Slide an opening pick under the battery and gently work it back and forth to separate the adhesive from the battery.
    • This adhesive is quite strong and will require careful attention to apply the correct amount of force to remove the battery without damaging it in the process. Be patient and take it slow.
  11. Motorola Moto G Power (2020) Battery Replacement, Out with the old, in with the new: 11 단계, 이미지 1개 중 1개
    • Remove the old battery and insert the replacement battery, connecting it to the motherboard.
    • (Optional) Two-sided tape can be used to secure the battery to the frame if the original adhesive isn't strong enough to keep the new battery in place also.
결론
To reassemble your device, follow these instructions in reverse order, excluding the battery removal, of course.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Harry Jung
회원 가입일: 06/23/22
778 평판
안내서 4개를 작성함
UC Santa Barbara, Team 1-1, Bator Summer 2022 UC Santa Barbara, Team 1-1, Bator Summer 2022 회원
UCSB-BATOR-SU22S1G1
1 회원
안내서 8개를 작성함
5가이드 댓글
THIS OS THE WRONG BATTERY!!!!! IT's ABOUT 1/4" TOO LONG!!! WTF?!?!?!
Tweedle - 답글
How hard would it be for phone manufacturers to create a back cover to access battery for replacement...but NO, they make it as difficult as possible so they can make money selling new phones and/or sell repair services.
Tony Kawon - 답글
I purchased my "not Motorola" KZ50 battery from an eBay seller, it was a drop-in replacement for the original battery. I did have to do my own "fold" for the flex cable, not a big deal. I used my own T3 screwdriver, the "free" tools included with the battery are worth what I paid for them.
Richard Ekblaw - 답글
This guide worked great for me! Thank you. However, a couple of suggestions to make it a bit better. On the first step, I had a little trouble separating the back. The back is attached with glue (the guide doesn't say this) and I wasn't exactly sure which grove on the edge was the back. And edge picture would be helpful. Also, while removing the back, most of the glue came off the back and was unusable for re-assembly. Some suggestion on how to deal with that would be helpful. I used a bit of double stick tape, which seems to work ok, but I'm mostly relying my protective phone case to hold it together.
Matt J - 답글
Ok, I looked at some other guides on this site and found a great deal more detail and help. So while this guide worked, but it's pretty lacking in detail. Take a look at this one for example, and how much information it has about how to soften the adhesives, notes on re-assembling the connectors, and links to re-assembling adhesive-attached parts. Motorola Moto G Play (2021) Screen Replacement
Matt J -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 21
지난 30일: 197
전체 시간: 11,999
