주요 콘텐츠로 건너뛰기
Motorola Moto G Stylus (2021) Screen Replacement
필요한 것
  1. Motorola Moto G Stylus (2021) Screen Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Motorola Moto G Stylus (2021) Screen Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Push a SIM tray ejector into the hole.
    • Remove the SIM card and tray.
  2. Motorola Moto G Stylus (2021) Screen Replacement: 2 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Before you begin, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your phone and disconnect the charger and any peripheries before beginning disassembly.
    • Lay the phone face down.
    • Heat an iOpener and apply it to the rear case.
    • Alternatively, use a hair dryer to heat the rear case until it's almost too hot to touch.
  3. Motorola Moto G Stylus (2021) Screen Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Insert an opening tool into the seam between the rear case and chassis.
    • Once you create a gap, insert an opening pick a couple of millimeters into the gap.
    • Slide the opening pick around the entire perimeter to sever the adhesive that secures the rear case.
    • If you feel excessive resistance, reheat the problem area(s).
    • Remove the rear case.
  4. Motorola Moto G Stylus (2021) Screen Replacement, Main Board: 4 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement, Main Board: 4 단계, 이미지 2개 중 2개
    • Use an opening tool to lift and remove the midframe.
  5. Motorola Moto G Stylus (2021) Screen Replacement: 5 단계, 이미지 1개 중 1개
    • You may need to use your heating device again to remove glue from covering the screws.
    • Use a T4 Torx screwdriver to remove all eleven 3.2 mm screws securing the midframe.
  6. Motorola Moto G Stylus (2021) Screen Replacement: 6 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 6 단계, 이미지 2개 중 2개
  7. Motorola Moto G Stylus (2021) Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the black tape covering the connectors.
    • Use an opening tool to lift and disconnect the four press connectors.
    • Use an opening tool to lift and disconnect the two antenna cables connectors.
  8. Motorola Moto G Stylus (2021) Screen Replacement: 8 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use an opening tool to lift and disconnector the front camera press connector.
    • Remove the front camera.
  9. Motorola Moto G Stylus (2021) Screen Replacement: 9 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Use a T4 Torx screwdriver to remove the two 3 mm screws securing the main board.
  10. Motorola Moto G Stylus (2021) Screen Replacement: 10 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to an edge of the main board.
    • Lift and remove the motherboard.
  11. Motorola Moto G Stylus (2021) Screen Replacement, Battery: 11 단계, 이미지 3개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement, Battery: 11 단계, 이미지 3개 중 2개 Motorola Moto G Stylus (2021) Screen Replacement, Battery: 11 단계, 이미지 3개 중 3개
  12. Motorola Moto G Stylus (2021) Screen Replacement: 12 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 12 단계, 이미지 2개 중 2개
  13. Motorola Moto G Stylus (2021) Screen Replacement: 13 단계, 이미지 3개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 13 단계, 이미지 3개 중 2개 Motorola Moto G Stylus (2021) Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the black graphite tape from the battery and surrounding components.
    • Use an opening tool to lift and disconnect the press connector above the battery.
  14. Motorola Moto G Stylus (2021) Screen Replacement: 14 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Use an iOpener or hair dryer to gently warm the battery to loosen to adhesive that secures it.
    • Warm the battery until it's uncomfortable to touch for more than a few seconds.
    • Use a spudger to gently pry around the entire perimeter of the battery until it fully releases.
    • Do not deform or damage the battery.
  15. Motorola Moto G Stylus (2021) Screen Replacement, Charging Port: 15 단계, 이미지 3개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement, Charging Port: 15 단계, 이미지 3개 중 2개 Motorola Moto G Stylus (2021) Screen Replacement, Charging Port: 15 단계, 이미지 3개 중 3개
    • Use a T4 Torx screwdriver to remove all seven 3.2 mm screws securing the black bracket.
  16. Motorola Moto G Stylus (2021) Screen Replacement: 16 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Use an opening tool to lift and remove the black bracket.
  17. Motorola Moto G Stylus (2021) Screen Replacement: 17 단계, 이미지 3개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 17 단계, 이미지 3개 중 2개 Motorola Moto G Stylus (2021) Screen Replacement: 17 단계, 이미지 3개 중 3개
    • Use an opening tool to lift and disconnect the two antenna cables.
  18. Motorola Moto G Stylus (2021) Screen Replacement: 18 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 18 단계, 이미지 2개 중 2개
    • Use an opening tool to lift and disconnect the press connector.
  19. Motorola Moto G Stylus (2021) Screen Replacement: 19 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 19 단계, 이미지 2개 중 2개
    • Use a T4 Torx screwdriver to remove the 3 mm screw that secures the charging port.
  20. Motorola Moto G Stylus (2021) Screen Replacement: 20 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 20 단계, 이미지 2개 중 2개
    • Carefully grab the charging port and slightly tilt it upwards.
    • This will allow it to be pulled outwards without bumping into the battery.
    • The cable might get in the way. If it does, carefully fold it upwards and out of the way. To prevent damaging it, do not force the cable to move in any direction. It should be able to be bent upwards with minimal force.
  21. Motorola Moto G Stylus (2021) Screen Replacement, Screen: 21 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement, Screen: 21 단계, 이미지 2개 중 2개
    • Carefully peel up the cable attached to the screen from the mid case.
  22. Motorola Moto G Stylus (2021) Screen Replacement: 22 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 22 단계, 이미지 2개 중 2개
    • Orient the phone so the screen faces up.
    • Use an iOpener or hairdryer to heat the screen until it's almost too hot to touch.
  23. Motorola Moto G Stylus (2021) Screen Replacement: 23 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 23 단계, 이미지 2개 중 2개
    • Use a pick to sever the connection between the screen and mid case.
    • Do not run the pick along the top or bottom edges of the phone. There are delicate cables that are easy to sever.
  24. Motorola Moto G Stylus (2021) Screen Replacement: 24 단계, 이미지 2개 중 1개 Motorola Moto G Stylus (2021) Screen Replacement: 24 단계, 이미지 2개 중 2개
    • As the glue gets severed, carefully separate the screen from mid case.
    • Carefully pull the cable out of the mid case.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
3다른 기여자 명과 함께
Giovanni Rodriguez-Ortuno
회원 가입일: 08/28/24
373 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 56
전체 시간: 604
