주요 콘텐츠로 건너뛰기
Motorola Moto G Stylus 4G (2023) Battery Replacement
필요한 것
  1. Motorola Moto G Stylus 4G (2023) Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Battery Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use the opening pick along the edges to separate the camera lens glass from the board. If you begin to pry where the picture indicates, you will only get the top plastic and it will peal away from the paint. Instead begin at the gap in the lower left hand corner where there is a space between the actual frame that contains the lenses and the phone.
  4. Motorola Moto G Stylus 4G (2023) Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Battery Replacement: 6 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Battery Replacement: 7 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Battery Replacement: 8 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Camille Holley
회원 가입일: 02/14/24
609 평판
안내서 5개를 작성함
2가이드 댓글
Thank you for this guide @camilleholley , it was extrememly helpful. Thankfully, the problem charging my phone (Moto G Stylus 5G, 2023) seems to be resolved with a fresh battery replacement.
>>>For anyone with this phone having problems charging, here's what I was experiencing: (a) battery would charge only with one cable (it was a USB-A to USB-C) (b) battery would drain extremely quickly once charged (c) battery would only charge to about 20% and then lasted for less than 1 hour with minimal to no usage.<<<
Also, for anyone reading this who's about to replace the battery - I recommend getting the battery & a magnetic dry-erase board project mat (~$20 USD) from ifixit. The battery I got came with a repair tool kit, and it had everything I needed to use to remove the back. The magnetic project mat was perfect for keeping the tiny screws in one place, and it even came with a really nice dry erase marker to take notes with (like how many screws go to a certain area or what the name of the removed part is/where it goes).
- You can do this! This was my first time taking this phone apart, and I'm not a professional phone repair person. While it took me a few hours to do (mostly because I was messing around with figuring out adhesives) I'm glad that I decided to save the additional money it would have cost to have someone replace it for me.
M. F. Espinoza - 답글
Can i get a Battery
Mahfujur Rahman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 101
전체 시간: 1,387
