주요 콘텐츠로 건너뛰기
Motorola Moto G Stylus 4G (2023) Screen Replacement
필요한 것
  1. Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Screen Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Use the opening pick along the edges to separate the camera lens glass from the board. If you begin to pry where the picture indicates, you will only get the top plastic and it will peal away from the paint. Instead begin at the gap in the lower left hand corner where there is a space between the actual frame that contains the lenses and the phone.
  4. Motorola Moto G Stylus 4G (2023) Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Screen Replacement: 6 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Screen Replacement: 7 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Screen Replacement: 8 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Screen Replacement, Screen: 9 단계, 이미지 1개 중 1개
    • Apply heat using a heat gun to soften the adhesive around the edges of the screen.
    • Avoid overheating to prevent damage to the device.
  10. Motorola Moto G Stylus 4G (2023) Screen Replacement: 10 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 4G (2023) Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Insert a Jimmy into the crevice between the screen and the rest of the phone.
    • Work around the edges to gently pry the screen away from the phone.
    • Be careful to avoid glass fragments from the broken screen.
  11. Motorola Moto G Stylus 4G (2023) Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the screen connectors from the motherboard.
    • Remove any screws that are holding the screen in place.
  12. Motorola Moto G Stylus 4G (2023) Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the screen from the phone.
    • Clean the frame of any adhesive residue or glass shards.
    • Align the new screen to check its fit to the frame. Place the new screen with new adhesive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Camille Holley
회원 가입일: 02/14/24
609 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 23
지난 30일: 94
전체 시간: 2,132
