소개
Use this guide to remove and replace the SIM card tray in your 2022 Motorola Moto G Stylus.
필요한 것
Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
Press firmly to eject the tray.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Cómo saber para que lea el chip
Hi! The SIM card tray has a recess on one side that the SIM card fits into. This recess has a notch in one of the corners that lines up with the notch in the SIM card. There should be only one way to fit the SIM card into the tray.
Howdy!
When I tried this, I found that the tray didn't come out far enough to get my fingernails underneath it.
I used a piece of scotch tape to pull it out a little farther, and then I was able to remove it with my nails.
It didn't seem like I forced it.
The trouble is that now it won't latch back in.
If I really push, it goes in far enough for the sim to register, but then it pops back out ~16th of an inch and pushing on it can't be good anyway...
I know it's a bit outside the scope of this article, but any ideas?
