주요 콘텐츠로 건너뛰기
소개
Use this guide to replace the Moto G4’s rechargeable battery. If your battery is swollen, take appropriate precautions.
For your safety, discharge your existing battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
  1. Motorola Moto G4 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Motorola Moto G4 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Motorola Moto G4 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Motorola Moto G4 Battery Replacement: 2 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement: 2 단계, 이미지 2/2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Motorola Moto G4 Battery Replacement: 3 단계, 이미지 1/3 Motorola Moto G4 Battery Replacement: 3 단계, 이미지 2/3 Motorola Moto G4 Battery Replacement: 3 단계, 이미지 3/3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Motorola Moto G4 Battery Replacement: 4 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Motorola Moto G4 Battery Replacement, Midframe: 5 단계, 이미지 1/3 Motorola Moto G4 Battery Replacement, Midframe: 5 단계, 이미지 2/3 Motorola Moto G4 Battery Replacement, Midframe: 5 단계, 이미지 3/3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Motorola Moto G4 Battery Replacement: 6 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement: 6 단계, 이미지 2/2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Motorola Moto G4 Battery Replacement: 7 단계, 이미지 1/1
    • Remove the rubber cover.
  8. Motorola Moto G4 Battery Replacement: 8 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement: 8 단계, 이미지 2/2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Motorola Moto G4 Battery Replacement: 9 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Motorola Moto G4 Battery Replacement: 10 단계, 이미지 1/1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Motorola Moto G4 Battery Replacement: 11 단계, 이미지 1/1
    • Remove the midframe.
  12. Motorola Moto G4 Battery Replacement, Battery: 12 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement, Battery: 12 단계, 이미지 2/2
    • Peel up and remove any tape connecting the battery to the main board.
    • Be very careful not to puncture the battery with any sharp tools. A damaged lithium-ion battery can catch fire and/or explode.
  13. Motorola Moto G4 Battery Replacement: 13 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement: 13 단계, 이미지 2/2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket with the exposed copper wire facing up, and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  14. Motorola Moto G4 Battery Replacement: 14 단계, 이미지 1/2 Motorola Moto G4 Battery Replacement: 14 단계, 이미지 2/2
    • Push the battery wires towards the battery to de-route them from the black bracket on the motherboard.
  15. Motorola Moto G4 Battery Replacement: 15 단계, 이미지 1/3 Motorola Moto G4 Battery Replacement: 15 단계, 이미지 2/3 Motorola Moto G4 Battery Replacement: 15 단계, 이미지 3/3
    • Peel up the black pull tab at the top of the battery, and pull slowly but firmly to separate the battery from the adhesive holding it in place.
    • The battery separates more easily if you add a few drops of isopropyl alcohol along each side, to soften the adhesive beneath. High concentration (90% or greater) alcohol will not harm your phone's components.
    • Heating the area behind the battery can also help soften the adhesive, but be very careful not to overheat the battery.
    • If the pull tab breaks, use a spudger or an old credit card to pry up carefully on the edges of the battery until it comes loose.
    • Don't deform or puncture the battery—it can catch fire and/or explode if damaged.
    • Never reinstall a damaged or deformed battery. Replace the battery.
    • Remove the battery.
    • During installation, note the orientation of the battery—if the connector is on the same side as the motherboard, and the text is upside-down relative to the rest of the phone, you've done it correctly.
    • Use a few strips of thin double-sided adhesive tape or a pre-cut adhesive card to secure the battery. (Or, if you are replacing the display, it may come with adhesive for the battery pre-installed.)
결론
Carefully compare your new replacement part to the original part. Remove any adhesive backings before installing your new battery.
After completing this guide, calibrate your newly-installed battery.
다른 44명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 2013년 08월 06일
396,679 평판
안내서 261개 작성하였습니다
iFixit iFixit 회원
Community
146 회원들
안내서 16,124개 작성하였습니다
15 Comments
Bought the battery from Ifixit because I’ve enjoyed your videos. I changed the battery, all seemed well, but now I get no sound out of the speakers! They are not mentioned on any of the topics. Help!?
Alex G Mendoza - 답글
See the comment on this step. Make sure the two little copper prongs on the back of the speaker make good contact with their respective pads on the back of the midframe. It’s okay to (very gently) bend them up slightly if needed.
Jeff Suovanen -
bought battery and kit from ifixit. replacement went pretty well. Careful with those tiny little screws. They do not like to come out after loosening. I worked over a small tray and still had two get away from me. I also had some tape on the sim card side of battery not mentioned in instructions. I tore it pulling it back. Was concerned as it seemed to be foil faced on back side which sepperated when pulling up. All works though so no worries.
Hugh Wolfe - 답글
Bonjour,
Etes-vous sûr pour le modèle du tournevis ?
J’ai échoué avec le Torx T3, mais réussi avec le Torx T4
LEFEVRE - 답글
It definitely should be a T3, but not all driver kits are created equal. If a T4 works better for you, go with that ;)
Jeff Suovanen -
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 133
30일 전: 640
전체 시간: 55,482
