소개
Use this guide to:
- Replace or remove the battery
- As a starting point for any other repair/replacement needed on the phone, since it's hazardous to keep the battery in
If your battery is swollen, take appropriate precautions.
필요한 것
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
