주요 콘텐츠로 건너뛰기
Motorola Moto G4 Play Charging Port Replacement
필요한 것
  1. Motorola Moto G4 Play Charging Port Replacement, Battery: 1 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement, Battery: 1 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement, Battery: 1 단계, 이미지 3/3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Charging Port Replacement: 2 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement: 2 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement: 2 단계, 이미지 3/3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Charging Port Replacement: 3 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement: 3 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement: 3 단계, 이미지 3/3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Charging Port Replacement, Midframe: 4 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement, Midframe: 4 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement, Midframe: 4 단계, 이미지 3/3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Charging Port Replacement: 5 단계, 이미지 1/2 Motorola Moto G4 Play Charging Port Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Charging Port Replacement: 7 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement: 7 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement: 7 단계, 이미지 3/3
    • Remove the back panel assembly with your hands.
  8. Motorola Moto G4 Play Charging Port Replacement, Charging Port: 8 단계, 이미지 1/2 Motorola Moto G4 Play Charging Port Replacement, Charging Port: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to pop up the antenna wire.
  9. Motorola Moto G4 Play Charging Port Replacement: 9 단계, 이미지 1/2 Motorola Moto G4 Play Charging Port Replacement: 9 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up on the connector at the bottom of the battery space.
  10. Motorola Moto G4 Play Charging Port Replacement: 10 단계, 이미지 1/1
    • Remove the two (2) 3mm Phillips PH000 screws securing the charging port.
  11. Motorola Moto G4 Play Charging Port Replacement: 11 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement: 11 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement: 11 단계, 이미지 3/3
    • Insert the tweezers under the vibrator and gently lift up the whole part.
  12. Motorola Moto G4 Play Charging Port Replacement: 12 단계, 이미지 1/3 Motorola Moto G4 Play Charging Port Replacement: 12 단계, 이미지 2/3 Motorola Moto G4 Play Charging Port Replacement: 12 단계, 이미지 3/3
    • Pop up on the vibrator's connector to separate it from the charging port.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Francisco Hernández
회원 가입일: 02/15/18
708 평판
안내서 2개 작성하였습니다
USF Tampa, Team S17-G4, Boczar Spring 2018 USF Tampa, Team S17-G4, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G4
4 회원들
안내서 11개 작성하였습니다
댓글 2개
Excellent guide.
The hardest parts were getting the “small silicon cover” off and putting the vibrator's connector back in.
I highly recommend people to take a photos of their phone’s small details for later reference when you put it back together again.
Slippery Jim - 답글
The hardest part for me was removing some of the screws, not to mention finding the proper screwdriver (tip: look at your local hardware store before buying online). The battery connector was a pain too, you just need to press it fearlessly.
generalwatermelon38 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 30
전체 시간: 5,690
