소개
Use this guide to replace the midframe of your Motorola Moto G4 Play if damaged, or to access the internal components. Consider using a magnetic mat to organize the screws that will be removed from the device.
필요한 것
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
다른 2명이 해당 안내서를 완성하였습니다.
